thanks snYou must have a Large dirt bike hanging on the front bumper. Or did you back up a bit on the scale and leave it in reverse with your foot on the brake. Time to weigh again and forget about being over GVWR. Say under axle ratings and enjoy. Snoking
Pretty sure the OP has a 5th wheel......he had a cab contact recently and broke his rear window and damaged the cab.
When you say "load levelers"....I *assume* you're referring to rear air bags.....and not a weight distributing setup?
My rule for figuring what RV your rig can tow is take your rear axle rating and subtract your actual rear axle weight with everything ready to tow. Full fuel, tool box, hitch misc and bodies.
Now take that number and multiply that by 4, that is the GVWR 5er you can tow based on a 25% pin weight. The last two 5er's I have owned have 25% pin. Full timing that is easy to do!
this is where I messed up. My 04 dodge dually had a gvwr of 12200.... The 2015 has a gvwr of 12300.. I did not think the 15 weighed nearly 1000 more .
Until you hit 8000 on the rear axle don't even worry. Get the heavier tires, if the fridge is in front of the axle store the food stuffs at the back until you arrive. It probably weighs more than the grill and hitch combined. As long you don't exceed axle and tire ratings it is solid.
Someone posted the the 18" wheels are only rated to 3500 each??? With 3:42 gears does one really want taller tires. Just what tire are you recommending? SNOKING
Factory rates rims at 1/2 the axle rating. Based on the weight and construction compared to wheels that have a true rating they look to be good for 3800-4000 lbs.
I did not say taller tire I said heavier tire. A 295/65/18 is actually .1 inches shorter that the 275/70/18. It depends on the profile of the tire.
Have no idea, OP said there was a tire in 295 that was rated for 4000 lbs so likely it was a 65 profile. Depends on who told him that and if they were correct. Tires rated a 4k per are in limited supply anyway but if you can get an AT likely can get an HT by order, or at least a less aggressive AT.
