Hello! I'm new here so thanks for understanding. So, about a week ago I got my truck (2011 RAM 5500 6.7 Cummins C&C) into the shop for a "Service DEF system will not start in 200 miles" warning. Before my mechanic and I did anything to the truck. He used a Snap-on scanning tool and Code P003A appeared. We did the DPF and DOC cleaning and put new gaskets in the exhaust system. All sensors were not damaged and DEF injector doser was also clean and free from any DEF crystals. Code was still there after the cleaning. However, after that I noticed a coolant leak in the return line of the EGR system and was leaking a lot of liquid. I'm not sure if the coolant had something to do with it but I did a LOT of research online and some experts suggest to check the engine wire harness and some fuses - M21 and Smart Power Relay.
I may need to buy a new Turbo but it makes me wonder why the *Exhaust Brake stopped working out of the blue. I did several trips out of town using the EB* and had no problems. Also, I downloaded some schematics online and I have an idea of what to look in the Turbo speed sensor and actuator harness.
Any ideas, comments, suggestions will be appreciate it. More more thing - truck runs and drives like a champ. No overheating or extra fuel consumption. Engine oil was changed to fully synthetic less than 100 miles, transmission oil (AS68RC) was also changed, DEF, Crankcase, Fuel (Nano), and Air Filters are new. Also EGR system was clean with no issues.
Thanks everyone!
Thanks everyone!
