160 thermostat
I had a customer last month that was having an overheating problemon a 96 4X4 auto quad cab long bed 2500. He tried the thermostat and made no difference at all. I suggested that he bring it in and let me do the KDP fix and at that time we could check the radiator since it would be out to give better access to the T/C to do the KDP. When I looked down between the rediator and the intercooler, I could not see anything that would cause a problem, however when I got the radiator out, it had about 3/4 of the fin area plugged with mud and lint. But it was about 1/8" below the surface of the fins so it was not visable untill the radiator was removed. It also had a header leak in a lower corner and was the old brass - copper - plastic type of construction. so I and my radiator shop recommended a new aluminum - plastic type unit. The replacement is only $269 at a local radiator outlet. Just thought this might help your friend get to the cause of the heating problem.
