2nd Gen Non-Engine/Transmission "HELP" regulator for fuel pressure gauge autometer.
Engine/Transmission (1994 - 1998) Batteries and tune up help
Engine/Transmission (1998.5 - 2002) Lift pump, or ?!?!?!
I went through four senders in three months and gave up. Took Bills advice and went mechanical with a 1/8 inch needle valve. But instead of using 1/8" nylon hose I went with SS braided lines... . looks prettier. :p
Oops???? Sending Unit?
All this talk about sending units never lasting and needing a snubber... I just installed one(a sending unit, that is). It is a Westach. Will I have problems without using a snubber(valve)??:confused:
Sender mounted off the motor ? if not move sender to a mount off the motor and connect with a fuel line with a loop if you wan't to dampen the pulse . If you have sender on the motor you can and will have problems . Fuel line with brass fittings work fine and can be found at Home Depot or other store of this type. A damper can be made with a drilled orfice of about 2/32" put and banded in line to gauge . But with loop or long line the line will dampen the gauge needle or reading of a didgetal . LOL Ron in Louisville KYOo. Oo. :D
Ron,
That doesn't work with a P7100 pump. It will still hammer a mechanical gauge or pressure transducer for an electrical pump and break them. I installed a snubber. That helped. Then I installed a needle valve closed so that pressure came up slowly on my gauge. The setup that worked is needle valve in banjo fitting on the side of the pump, snubber, and a gease gun hose. The line to the mechanical gauge started there. Now there is a pressure transducer for my new pressure gauge. I'm hoping the trasducer will survive for a while since I really like my Westach 40 PSI gauge.
There doesn't seem to be a problem with the Westach sending units as there are with Auto-meter. In fact when I talked to AM about 4 months ago they said they were considering adding a label saying "Not for Diesel". Did they ever do this. Seems the best thing to do is fix the problem rather than to ignore it. :rolleyes:
Had the same problem with my A/M senders. The tech guy told me they started using a different supplier / different sender.
The original ones (which lasted about a month - direct mounted to the filter housing) were silver/aluminum colored and were about 1&1/2-inch in diameter. The new ones are brass colored and about 3/4-inch in diameter.
The new ones are "supposed" to hold up better, but I use a needle valve and have them remote mounted now.
When I turn on the key it takes about 3 seconds for the needle to climb up to 13 psi.
So much for the new senders from A/M,I have gone through 2 of them and it still does not work. As soon as the pressure gets around 15 lbs the gauge pegs and stays there. Am going to try a snubber and see if that works be for going to a mech gauge.
Sorry about that
That's a shame. My pump never puts out more than 14 and the new senders have been in for over a year. Maybe there's no "headroom" on that sender -- they say 0 - 15 psi -- I guess they mean it. :confused:
