Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Engine/Transmission (1998.5 - 2002) help truck wont start
Engine/Transmission (1994 - 1998) 3rd gear syncros
i have a 02 with a comp box, stage 3 jammer injecters, 95gph fass w/filters. about 6 months ago the truck wouldnt start when i was in town. i drove it to city market shut it off and bout 30 mins later tried to start it and it wouldnt start. i had fuel to the vp and had fuel out of the injecters. and the truck still wouldnt start so i let it sit for about an hour and it fired right up like it didnt have any problem. i drove the truck home and the next day it started and ran fine i shut it off three to four time and it started back up every time. but the next day it i drove it and it wouldnt start after i shut it off. i let it sit for an hour or so and it fired right up. so from there on i drove my other truck and let it sit but i went to drive it one night and it wouldnt start up. i tried every day for 2 weeks to start it and it wouldnt start so i took it to the mechanic and he said it was the vp. but i went to pull it home (cuz i didnt have the money for a new vp) and it fired right up so i drove it home from the mechanics. i have put a new cam shaft p/sensor, all the fuses are good, unplug the comp and still no change, i try to start it up every now and then and it doesnt usually start. i tried to start it last night and it wouldnt start (i have fuel coming out of the injecters and the fass cycles) but today it started and it runs great i drove it around town. i cant figure out how if the pump is bad why the truck runs so great and why it wont start. could it be a ground or ??? i have got a 1693 and a 1689 dtc by cycling the key but never a check engine light since the problem started. but i didnt have them cleared so any solutions would be greatly appreciated
I found a 99 with this symptom that had a bad ecm. The drivers that send 12 v from the ecm (differing pins) to the PDC fuel ip relay that allows for power at the IP connector (Pin 7) and the transfer lift pump fritzed out and wouldn't supply votage after the engine warmed up, then voltage would slowly drop to about 7-8 volts, the relay would open and the truck would die. It wouldn't recrank until it cooled off and/or sometimes when the battery - cables were disconnected.
Hope this is not your prob.
Do some through troubleshooting or have someone do it for you before changing out a lot of parts. . hoping to get it.
FWIW, I don't find too many failed ECM's, which can't be said for the IP and LP.
Good luck
Andy
haha, now thats funny ether is my best friend in diagnostics, I have never had it explode on the intake heater, I have always sprayed it right into the intake tube on the turbo. (great way to bleed injectors on a 2nd gen if you don't have somebody to help)
see what that does
tried a little ether through the turbo truck ran on ether but as soon as it burned it up it died. i cracked 3,4,5 injecters and they all have fuel coming out of them
Just becuase the VP44 will squirt fuel at the injector doesn't mean that it will do it at the proper time or will produce enough psi to fire the injector.
It sounds like VP44 time. You FIPM (fuel inj pump module) likely is toast.
Double ck. for 12v at pin 7 (red/light green tracer) of the IP elec. connector and good grd at pin 6 (black w tan tracer).
If not ok, temp. connect a power and grd to the pump with the IP connector removed, it should start and idle only. If not you have a elec. harness prob. or ECM prob.
Good luck
Andy
