Archived Help, Trucky wont starty
Archived dodge quit working
Archived Front brakes won't release-help!!
2 days ago changed fuel filter same as I always do and now just cranks wont start. Can someone head me in a direction? Please and thank you. HooperB.
afterthought, its 98. 5 24 valve. lift pump is pumping, removed nut on top of filter and have a fuel geyser, thats how I fill up the filter, just bump starter and lift pump runs about 10 sec. Can the engine flood or could I have a vapor lock. How do I check my inj. pump?
Right on Lumberjack, shes up and purring! Just joined this site to see if I could get some help. Best 35 I ever spent and thanks Bob for your suggestion too. Man that was the best sound I have heard in a long time when 'Ole Ruby" cranked over... ... .
Mine was similar once i had to crack the lines at the injectors to purge the air. if you want call reb at browns diesel and he can help. 559-355-4433.
