Help us Help.
'06 5.9 w/Truck Camper with P2122 Code and in limp mode
2015 ram 3500 6.7L wont charge, goes into batter saver mode
Austin you would get more traction posting in the model year range forum for your truck.
I would only use a Cummins/Mopar (relabelled Cummins part) cmp sensor (in case you got the oreilly/auto zone variant). If your Bosch FCA solenoid came from amazon or ebay it could be counterfeit, even though it might arrive in "Bosch" packaging. If from a reputable online store likely ok.
P0088 is not always injectors. You need a good diagnosis it sounds before firing a parts canon at it. Many of the engine sensors share a spliced 5volt sensor /sensor ground from the ecm harness. If the wiring diagram for your truck's Vin is followed voltage drop testing could be performed on the wiring.
A quality tech with a good aftermarket and/or Witech can tell alot by ruling out what is "ISN'T"
Good luck
Andy
