It was a piece of cake... I took all the fuel lines 2 bundle of 3. #6 was a little hard but if you get a 19mm stubby wrench,it makes it alot easier. I got a mirror to get the keyway at 12:00 or look at the line on the gear as to be at 7:00,then you will know that the keyway will be at 12:00. I used a regular steering wheel puller,it worked great. The bolts on the injection pump were easy to get at. When i installed it i put a little oil around the o-ring on the pump and it helped to go in. Thanks guys again. Rick
