Engine/Transmission (1998.5 - 2002) HELP! Wiring connector!
Engine/Transmission (1998.5 - 2002) diesel sound change
2nd Gen Non-Engine/Transmission Up Front Pusher Cooling Fan
I need to know where or what the 2 wire connector that is right with the 3 wire triangle connector that you guys say is for hooking into for boxes and such. Not the triangle with the cap on it but the 2 wire plug, I believe that one wire is black and the other is red/white stripe. Thanks!!
Even if you don't know but have a truck like mine would be a great help!!!
Mine does not "go to" anything. It is just capped off as is the triangle plug was from the factory. I took two pics , but they are too big to post here. I'll e-mail them to you right now if you'll give the address.
-- email address removed --
It is just a rubber plug, it is not a "shorting plug" that connects them together?
