Help with a code Please
low/lost anti-freeze
Oil filter compatability
I just decided to check engine codes by the key method and found
P2509 ECM/PCM Power Input Signal Intermittent
I've not seen a check engine light and the truck seems to be running like it should,winter fuel and all. The only trouble I've had is a couple no starts due to real cold weather. (block heater is tits up)
Could somebody enlighten me as to what might be going on?
Do a search on the forms-click on the link below.
https://www.turbodieselregister.com...sions-2003-2007/210513-p2509-engine-code.html
