HELP WITH A PILLER COVER
VIOLENT shaking/vibration
Hobbs vs. Miles
Can anyone tell me how to get my piller cover off on my a piller on my 2000 dodge so I can install my gauge pod.
2000 DODGE SLT,ULTRA-RUNNING BOARDS, AMERICAN TOOL BOX/FUEL TANK,AND REESE 20K HITCH,GTS BUG SHIELD,RHINO LINING . MEDIUM SIERRA BRONZE, QUAD 2500 LONG BED. 4:10 POSI-TRACTION REAR END W/AUTOMATIC. STAN'S 4" EXHAUST SYSTEM TURBO BACK, AND VOYAGER BRAKE CONTROLLER,PIRO/BOOST/AND TRANY GUAGES. ULTRA-BOARD MUD FLAPS. HEAVY DUTY TOWING AND ALL ACCESS. A POSI-TRACTION 4:10 REAR END. K&N AIR FILTER. MOPAR DEEP ALUNIUM TRANY PAN. KLEEN WHEELS, DD STAG 1 INJECTORS. CUSTOM BURLWOOD DASH KIT AND WINDOW SWITCH COVERS. 29' ALPENLITE 5TH WHEEL W/SLIDEOUT. 5" GENO'S CHROME EXHAUST TIP. STULL ALUMINIUM BILLET GRILLE. STAINLESS WHEEL OPENING TRIMS. POWER VENTED TRANY COOLER. Hellwig 3500 progressive overload springs.
If it is a full cover,I left mine in place. Ran the wires up between the pillar and the dash, between the cover and the pod-cover, held it in place, drilled the holes and pushed in the clips, done.
OOPS! Forgot you have the Tweeter.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
[This message has been edited by Paul (edited 06-06-2000). ]
Alpenlite,
You have to pull it STRAIGHT out. Straight as if you are trying to reach thru the drivers side window. The clips hang onto the a-pillar clips like fish hooks. Its easy to break it. Yours may be a little different than mine. Revised clips ect. Ypu may want to leave it in place. If you have to remove it. Try to be gentle. I broke mine trying.
Here is D. I S. Instructions for removing the A Pillar: http://www.dieselpage.com/art0299fp.htm
See my thread in Products/Accessories "A-Pillar removal... SNAP!!!!!"
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 06-06-2000). ]
Thanks for the help I appreciate it.
Be careful, if you break one with tweeters it will cost you. Dodge wants about $125.
Randy Richmond, 98. 5 24 valve, 2500, 5 speed, 4x4, 3. 54, LB, QC, Van Aaken CPC, PacBrake, Walker flowthru muffler, Amsoil, running boards, Leer Shell, Metalic Red.
Randy, Anything unique about the A-pillar with tweeter other than its high price? I want to put gauges in my A-pillar and I've got the tweeter. Beyond "Be Careful" is there anything else I should be thinking about?
1999 White SLT QC LB 4X4 AUTO CS TP SB-Stainless Nerf. Will Bomb for Adventure!
Alpenlite,
I got mine out no problem. Just be careful I started at the top pulling straight out and down (like pulling a lever). The pillar cover kinda hangs on at the bottom just rock it gently back and forth while pulling it upward towart the roof. Unhook the tweeter connector and your done.
Jim
Patriot blue Y2k 5sp Stealth 2500 (markings removed) QC SLT+ leather camper TT lsd 3. 54 4x4 hd xfer case Geno's dual gauge, DD IIM's and boost module ARE lid & bedrug liner sony 10 disk cd changer.
[This message has been edited by jims (edited 06-12-2000). ]
Alpenlite: There is something else you might consider: How about LED's wired to the secondary side of the toaster relays to indicate when the grids are on. They cycle back and forth as the engine warms up and is an indication that the toaster relays are working. I mounted them in the A pillar cover, used yellow and they are neat.
Thanks guys for the help. The cover pulled straight out with no problem and the gauges look awsome.
