I just installed the 230/605 TST plate in my '98 5-speed last weekend. The plate is installed in the stock position. I also installed the AFC spring (the stiffer of the two) at the same time. The AFC housing was slid forward per instructions. I have adjusted the star wheel several times trying to get better low RPM response, and have it now nearlly completely backed off. The problem is it is a real dog off the line, as in worse than stock. I've even killed it a few times starting out in second gear. In doing the adjustments, I never encountered any smoke until the star wheel was backed completely off. When I say "backed off" I mean screwed toward the front of the engine. What am I doing wrong? Do I need to go to the lighter of the two springs in the kit? The truck has gobs of power starting at about 1650 or 1700 RPM. Suggestions?
