Today i took a sick day to do a much over due brake job on my truck. I got some new rotors and the rotor and the hub are a seperate unit. I hammered out all the old wheel studs and this seperated the rotor and the hub. The problem i am having is putting the old studs back into the hub and new rotor. I have tried a couple things using my impact put some washers on the stud then the nut and tightened it to try to get it to seat. I even put the hub and rotor on the truck then put the tire on thinking this may pull it together more evenly. Both methods have left the studs about 1/8 inch from seating. any ideas??
Thanks in advance
Thanks in advance
