Code
Turn off your ignition, on, off, on, off, on and wait. Do not start the truck. A P Pcu code will flash any codes, then it will say P Done. Next it will display P Ecu. Next it will falsh any codes in the Engine Control Unit. Then It will flash P Done. This is how to display the codes in your PowerTrain Control Unit and Engine Control Unit. You switched your ignition in the correct sequence to initate the computer code readout.
