2nd Gen Non-Engine/Transmission Help With Factory Foglight Wiring?
2nd Gen Non-Engine/Transmission About the ATP Quiet Kit
2nd Gen Non-Engine/Transmission Fuel tank sending unit - rebuild / rework
i mounted piaa 510's on my 96. you can by a mounting kit from piaa for our rams. i believe the part # is either 30190 or 30195, depending on the year of your truck. i used piaas wiring harness with a factory switch
Fog Light Factory Install Kit for 134.95+ tax
Guys I have a 01 SLT. Didn't come w/ foglights. In November of last year I bought Installation kit at the dealer. The kit comes complete with lights, headlight switch, wiring, relay, bumper inserts, and mounting hardware. Simple install. I have the installation instructionsand the contents papers. I can't find hte inviovce for part number. I keep looking and will post when I find them. The price I thought to be great 134. 95 + tax. This may seem cheap but thats it.
kit part number
Bunyan,
Did you ever find the part number for that kit?
Kev,
I noticed you are installing the Catz fog lights. Did you get the entire kit(lamps,plug-in wiring harness,single relay switch, Led Power Swithch and safety fuse)? I had mine installed years ago. Seemed pretty straight forward( I still have the schematic). j I didn't have to take the bumper off('95) to install the lamps. They fit very snuggly into the holes so didn't need to use the brackets. My only problem,presently, is that I can't seem to find a bulb(lamp?) replacement. One of the lamps is burned out. Where did you get your Catz lights?
Jim
