Help with Fass Fuel Pump
Oil Leak
Pyrometer was twitching
trm1978
I am tired of these lift pumps going out. I have been looking into Fass fuel pump. I really don't know which one i need. How hard is it to install. What other parts will i need or does the kit come with everything. Does it make a difference that the dealership installed an in tank fuel pump. :confused:
Its not a hard install - just takes some time. I welded a custom bracket on my 150 to pull it up farther under the truck. There is only one thing I don't like about it and the same complaint probably applies to most of the aftermarket pumps that us a separate pickup tube. Fuel slosh - When I get to a 1/4 tank the fuel will slosh to the front of the tank during breaking and I get a momentary period when it is sucking air and fuel pressure drops. As long as I don't let it get to 1/4 tank it is fine. It seems we need much better baffles in these tanks. Outside of that one complaint, it holds pressure @ 15 PSI and so far has worked flawlessly.
Will the 95/95 be good enough if i go with more upgrades. My plan is larger turbo an intercooler. Maybe a TS performance Nitours kit
Get a FASS with the filters for sure. We've never had trouble with lift pumps. We just put on a FASS and forget about it. More power better milage less hassle.
