well hopefully I can get some input on helping a friend he has a 99 dually auto. with 200k miles changed fuel filter, oil new bhaf. did a air test no boost leak. no codes according to my smarty. he has no gauges which im pushing him to get. the problem is I believe centered around the transmission. I know it needs flushed and probley the bands adjusted. I know it hunts for gears. the worst is hitting about 50mph on a slight hill it will shudder like it wont down shift. is this the band adjustment or possible bad tq converter. what are signs of bad tq-converter. he doesnt blow any excessive smoke he doesnt have any performance add-ons. also seems the truck has almost a dead peddle takes for ever to get response at times with the peddle. if a apps is going would it throw codes. also the apps reset is it the same process for all 98. 5 to 02. well maybe you all can get me some tips to check out.
thanks.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2
" 4"EXHAUST D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf... THANKS RIP Source Automotive Light Truck Diesel Performance - Home
thanks.
