Hello, guys.
I almost posted this in the 911 section. We are about 6 hours from home. But the truck is running, although not very well.
We topped off (8 gallons) with diesel fuel near Pinehurst, GA then the truck lost power. Wouldn’t exceed 60 MPH. Stopped at a rest stop to check things out. Took a 1/2 cup fuel sample from the filter housing drain to check for water with the engine still running. The diesel proceeded very slowly out of the valve. Eventually the injectors started sounding very erratic then the truck died while I had the drain valve open. I didn’t think opening the drain valve caused it to die but maybe that’s possible. After the engine quit, I primed the filter housing by cycling the key. It didn’t restart right away but eventually it did restart. Anyways, more of the concern is the loss of power.
The low pressure electric pump is working. I checked that.
Does the CP3 pump fail in this manner? It’s not totally dead yet.
Is it possible to get water in the fuel and never see the light come on?
2003 3500 2wd manual transmission. 180,000 miles.
Thank you for any help,
Paul Lohr
Paul Lohr
