check the fuses ... easy way
With the great number of fuses, sometimes there are several inline for the same thing and it CAN indeed be a hassle to find a blown fuse.
What I do is take a multimeter, set to check continuity, and just stick one probe down on each of the two exposed sides of the fuse that you see right on top. A needle swing is easier to see than a digital in this check unless you have a digital one that will beep when you have continuity. Takes about 3 minutes to check all of them.
