Well I finished up the turbos around 9 last night. With clean up and the tieing up all the loose ends I was done at 1am. It took about 20 of my man hours and I guess another 15-18 from friends to complete. I bet I could do it again in half the time. It was a fustrating install bcause every time I took 2 steps forward I had to go one step back. I swear I installed every part at least 2 times. If anyone else does this put the 120* brass fitting on the big turbo before you put it in the truck and have it face toward the block. That fitting alone took over 30 minutes to tighten. I had to use a crows foot wrench hooked to a swivel extension on my flex head socket wrench to get it tight. I think I have a small oil drain leak on the top turbo, but other then that it seems fine. The kit is really a slick set up and I am pleased with the power so far. I only have a TST for a programer and it dones't have the twins program yet. Every once and a while I get a stumble at idle. When I ran it at 7/7 the turbos surged alll the way through the rpm range. I am running it on 5/5 and it surges a little, but you can control it. I have a feeling the fueling curve is way out of wack for the air. The truck is much more drivable then before. The 100 hp injectors were hard to keep smooth with out the air and they smoked from idle to 3200 rpm. Now it only smokes when I get on the go peddle
. I now have to send out the TST and then I am going to the dyno. Then I might still have to get the Smarty. Right now if I had to guess with the seat of the pants test I bet I got an extra 100hp, but I bet I can get another 100hp with tuning. I post up when I get to the dyno with some actual numbers.
BTW, flogging it I only got the EGT's to 1054 and the boost to 40 PSI. Does any one know if I need to adjust the waste gates or if 40 is the limit of the sensor because it reads through the TST and factory sensor????
I also put on the in-line PAC brake and if you have a NV5600 it fits real nice were the head pipe from II ends.
Hopefully some of this info helps the next guy. Unfortunately I did not take many pics because I had to get it done.
Thanks,
Aaron
Thanks,
Aaron
