help with jeep 2.5l to a 4.0. conversion
So much for "peaceful" protesters
Weapons-Grade Plutonium Possibly Found at Iraqi Nuke Complex
getting ready to swap out the tired ol 2. 5l motor and man trans for a new 4. 0 and a reman man trans. is there anything else that i need for this swap? ie different driveshaft lengths, mounting brackets, transfer case adapters? any help is appreciated. thanks josh
I think the transfer case will bolt up to your new transmission. I'm not sure about drive line length. You'll probably need the 4. 0 motor mounts. Do you have the wiring harness and ECM for the 4. 0? How about the radiator, that 2. 5 probably has a smaller radiator then you'll need with the 4. 0. Is this in a Wrangler?
