Got the hitch on yesterday... . Blue Ox.
It was an easy install, No issues. Also I fixed the hitch angle shown in previous pictures. I loosened the bolts that attach it to the frame, hooked the trailer up and took it on a bumpy road. That dropped the receiver right back down to where it belongs. Moved enough to have to reset the hitch height.
I learned a thing or two installing this hitch.
The instructions say to:
- Level the trailer.
- Measure to the top of the trailer's coupling and measure the trucks wheelwell heights front and back... . record.
- Set the truck ball that measurement (trailer tongue ball height) plus 1/8" for every 100lbs tongue weight. I needed and inch.
- Hook up and lock the ball. Raise both the truck and trailer with the tongue jack 3-5"
- Install the bars with the chains with no slack and lock the chains.
- Lower the tongue jack and your wheelwell heights should be within 1/2" of the previously recorded measurements.
- Adjust the bars to fine tune.
I also had to set the proper head angle that resulted in 5-7 deg pin angle (the pins that the bars pivot on) and about 11 deg for the bars.
When I was done the back was a little low so I added some air to the bags instead of loading the bars more.
Took it for a highway test drive. Runs down the road beautifully. No sway and much better manners than the previous hitch with the bars that were too light for this TT.
I'll see if I can get some pictures. I forgot to take them. It's unhitched now.
