New to the forum here. I installed a Westach fp gauge over the weekend along with a EGT, boost, and transmission temp gauge. I noticed after the install that my fuel pressure was low, and thought that it was luck I installed them when I did. I took the truck to the dealer to have the lift pump and fuel pump checked to make sure they were ok. The master tech at the dealer put their manual gauge on and the fuel pressure tested right on the money. I used the hose that attached to the schrader valve on the fuel pump to install my gauge. My question is, how tight should this hose fitting be, and if it were loose, could that have caused my gauge to read low. Thanks in advance for any help you can give.
