I changed out my fuel filter on my 98. 5 and found my lift pump was bad. I replaced the lift pump, bleed the lines to the injector pump, ran the lift pump through the 30 sec cycle about 10 times, then tried to start it--wouldn't even hit. then i cracked 3 injector lines and after cycling the lift pump 10 more times cranked it over to bleed the air out of the lines while holding the throttle to the floor. did this about 3 times for about 10 seconds each time. the engine hit a few times and about started. so I closed the lines and tried to start it, wouldn't fire at all. it looked like only a few dribbles came out of the lines. i then noticed the next time i tried to cycle the lift pump it ran smooth like there wasn't any pressure held. so i cycled it about 5 more times before it sounded like it was working against a load. re did everything stated above with no luck. any ideas.....
