Here is a copy of a thread i posted in the 24 engine and transmission forum under one thing after another.
I need all the help i can get, this truck is my only form of transportation... .
2-12-07
Ok, The check engine light come on about a week ago, read the codes found out it was a failure in the grid heater circuit, turned out to be the relays were worn out, after a quick rebuild on the relays i got them working again, Cleared the codes, check engine light still on, different codes this time though, now it is showing low voltages on boost sensor and intake air temperature sensor... I am at wits end guys, after running limp mode for over a week I am getting annoyed. I can't even pass someone easily anymore. any idea where i should go with my repairs next.
Kevin
2-12-07
I am getting the following codes:
0237 - Turbocharger Boost Sensor A Circuit Low
0112 - Intake Air Temperature Circuit Low Input
2-18-07
well things have gone from bad to worse... . I am getting lights for cruise control (my truck doesn't have cruise), water in fuel (has been unhooked since the fass was installed last winter), check gauges, the temp gauge pegged and the heater wasn't even blowing hot air yet, the throtle position sensor has crapped out on me. I am not sure where to even start on this one guys.
Kevin
2-12-07
Kevin
2-12-07
2-18-07
Kevin
