Took the truck to have the oil changed and the drain plug now leaks,leaves a large puddle. Went to the stealer and got a new gasket,and it leaks also. It seems the gasket will not cover the four indentations around the drain plug. What are you guys using? Has anyone else had this problem? If so how did you fix it?
Is there a better gasket available? If from the stealer what is the part number. My truck is a 96 CTD
