For those of you who are not contortionists, I have accidentally backed into what appears to me to be a much easier method of dropping the fuel tank. If it works as planned, it will certainly make it easier for subsequent tank removal. The manual says to first disconnect the push-on connectors and the fuel gauge sending wire. I tried that and wound up putting a rather nasty kink in the thermoplastic line which leaks air profusely. My solution is cut the plastic line and replace them with 2 foot of 5/16" and 3/8" ID quality rubber/neoprene fuel line and hose clamps. In attempting this I have found that the supply line tends to suck air when only using the hose and clamps. If one is careful, you can cut the QD fittings from the thermoplastic line with a razor blade or sharp knife, then push them into the rubber line and clamp them. You will also need to cut the plastic line from the metal lines alongside the frame rail to enable installing the rubber line and clamps. Allow the rubber line to coil around the sending unit and fuel tank nut upon re-installing the tank taking care to keep it from getting caught between the frame rail and tank. A couple of ziptype wire ties works nicely to keep the lines together and from rubbing. If you really want to get fancy, one could even go so far as to get some plastic wire loom to encase each line then wire tie them together and it might even make the install look a bit more professional to boot.
Next time, when you find a need to drop the tank, you wil only need to disconnect the sending unit wire and then ease the tank down to the ground using the slack in the rubber fuel lines rather than doing what happened to me causing the plastic to bind and crack.
I am looking for a supply source for the OEM QD couplers as I type just in case one were to get broken (and the inner plastic clips are a bit fragile). They should be rather cheap, but the only place I have found that distributes them won't sell except in huge quantity.
Edit: I found the small plastic insert retainer clips at Advance Auto, Dorman# 800-006 (5pcs. ) for the 3/8" insert and # 800-005 (5pcs. ) for the 5/16" insert. Total cost for 1 pack each was $7. 18 tx incl. Cost more for the packaging than the actual parts!
