The VVT Hemi (2009) should do much better in the Mileage, the 5. 3 GM gets awesome mileage. When we run the 5. 3 on the can it runs 14/16 minutes even with forced cycling,The 5. 7, 4. 7,3. 9, and the 318 maybe run 8 minutes. The only problem with the VVT is quality lube needs to be used, if you don't the Valve gets a film and sticks, not good for running the same cylinders off for long periods of time, its a easy fix but cost $200. 00.
