Not with thoes mods..... You'd be lucky to break 530HP
I dont think anybody that is at 600+ doesnt have a TST.
You need a TST and a alot more air.
600 is easy and 700 is almost unheard of for a moderately built daily driver.
I'm not a pro builder but im a pro web bomber. Its not going to be easy and its gonna take lots of dyno time to dial it in.
You will need a triple stack
(BDDL Crazy Larry, TST, MP8) or (Smarty, TST, MP8) or the Future EFI live
Large single like Silverbullet or similar or a nice set of twins possably custom set since I havent seen too many 700+hp guys running BD or ATS.
Everything GDP sells (walbro kit, Big line, 2micron, fuel water sep)
Major CP3 mods like stage 3, Dual feed line and larger rail and maybe PPE dual CP3's will be the ticket by then.
larger injectors, Springs, O-ring the head and studs, and then the common things like exhaust, gauges etc... .
Finally I think you should shoot for 600hp and see how you and your truck likes the 600HP level and then and only then decide if its worth it to go up to 700HP and give up a fair amount of driveability. You do realize that your most likely going to have to get a Dual Disk clutch and that mean's that you will be kissing alot of driveability and genral niceness away... .
700 is a big number and I'd reccomend that you team up with a trusty diesel builder who has done this kind of thing before since 700 isnt just a bunch of bolt ons but requires lots of machining and tuning since there sooooo many variables into making a 700hp rig. You will have over 100 combonations in electronic tuning levels, Turbo tuning, ect.
Goodluck and plan on spending lots of $$$. I know D. Wiggs has been putting together a similar set up and is way over $50,000 with similar goals but he's mainly on DTR and I got banned from there last month. .
Dan
