Hey Bob Wagner
best drivablity at 450-500 hp...??
Advice on CP3 Mod
Are you guys working on or do know of anyone working on a programmer for our trans?
It would be great if someone could make one to make our trans shift like they do on a Ford or GM when you use a programmer.
I had mine into the dealer to try to fix the 2-3-2-3 shift nightmare with a govenor press. solenoid and a re-flash on my 05 and when I got it back it shifted worse and not near as firm as when it went in. :{
I just did the same thing as you with the same results.
I find that running the Smarty JR on my 05 I am having the same issues with shifting as we have with the second gen smarty nightmare. It is not nearly as bad as sec gen but is obviously noticable. It gets better when I go back to stock.
This is a common problem with 04. 5 and up trucks with the acctuator. You should do a serch and the boards for it since it has been discussed a few times, but a DTT shift enhanser will take care of that problem. Give me or DTT a call @ 1-866-504-4002.
Richard
My # 786-543-9176
