Both turning and pulling out the diaphram have the effect of pushing the pin in. Turning the diaphram rotates the cone towards the lean profile, which in turn pushes the pin back towards it's "hole". Perhaps it is just poping back in and getting stuck again. I think there is an O-Ring around that pin, on the inside. If the O-Ring is bagged it will cause the pin to "hang up" and get sticky. I don't know if you can replace just the O-Ring.
Has anyone done this?? Did you do it while the pump was on the truck??
Have you tried spraying silicone lube inside the pin/hole to see if that will help free it up. I'd first use a can of comressed air (like a "dust off" from radio shack" to blow out any junk then spray silicone lube from either end. Silicone won't deteriorate rubber.
It may "refresh" the O-Ring enough to let the pin move. Either way though I think it will need replacement sooner of later.
Bob.
Bob.
