Engine/Transmission (1998.5 - 2002) hi
Engine/Transmission (1994 - 1998) Fuel heater/Lift pump
i just got fass put in need to know is that at idle have 13 psi and half throttle it goes down to 10 psi is this right when i ordered my fass i was told by dealer that it is 16 psi at idle and goes down a little bit so whats up
Which fass do you have, the pump only or the one with the filters?
The Fass has the filters "Fuel air seperator system".
The pump alone is called the HPFP "High performance fuel pump".
Just a FYI. :)
Don't confuse them as This can really mess you up while troubleshooting as they can be set different.
Just a FYI. :)
Thanks, I didn't know that. I have HPFP 95.
RAMMAN-MN, the 95 and the 150 are different pumps.
I had the exact same problem this weekend when I did my install, I had an air bubble in my guage/isolator hose. I blead it out and now have 14. 5 idle and 12. 5 WOT towing Heavy, can't even pull it down lower! Check your guage again. by the way what filters came your yours?
fass dan
i have called 7 dealers and they say any ware from 15 to 19 psi but below that just puts bad things with the vp-44
