returning from Tulsa w/ 5th. Went to Tulsa. truck was running ok. speeds 70 - 75 in od, egt 1200 max, boost 26 -30#. On the return trip ambient below 40* about 30 mi E of Amarillo the engine hicuped twice in about 5 sec. could not hold speed in od, could not get lockup in od. ran in 3rd @ 3000-3200 for the next 200 mi. lock up in 3rd ok,could shift in and out of od but no lock up and could not hold speed, in od 2200 rpm, no lock up egt could hit 1500+ boost 36#. In 3rd lu 3k rpm, egt 1250, boost 32#. Stopped at Sant Rosa for fuel and food, 5 min cool down and shut down for 1/2 hour. Started truck and truck was ok again. OD lockup, would hold 2k rpm, egt 1200, boost 24 - 30#.
My questions: why the increase in egt and boost and loss of power???
. Why no OD lockup
. Which computer would keep the tc from lock up and/or what the " L " is going on.
. If it needed a reflash it would not have healed it's self. I have to assume an electronic component is changing value and causing the puter inputs and/or out puts to go hay wire. Any ideas on which computer could caue this.
DC will not have a clue so they are out of the loop. I will replace what ever puter is failing but don't know which one????
2K, 2500, Laramie, Quad, 4x4, 3:54LSD, A/T, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, DD2's, Bully Dog Boost & elbow, ISSPRO pyro & boost, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, onboard.
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SOC-LIFE, SASS
[This message has been edited by JNutter (edited 02-12-2001). ]
. Why no OD lockup
