Hidden Antenna
Does anyone know where to find a remote lube oil filter kit?
Rancho 9000s--Where
Today I saw a device called "Hidden Antenna". It plugs into the vehicle radio in the antenna hole then the vehicle radio antenna plugs into the device and the C. B. antenna lead attaches to the device in a different place. Supposedly uses the vehicle radio antenna as the C B antenna also with no additional C B antenna required.
Anyone (Shawn?) know whether these things are any good?
Its a neat solution to where to put the C B antenna----It they are any good.
Vaughn
I thought that was a pretty neat item too until I researched it a little further. It seems you can only use the antenna for one or the other radio. you couldn't use them both at the same time. It has been a while since I looked at one but I imagin its the same today. I can't forsee a antenna transmitting and recieving at the same time. At the time I couldn't do with out the radio (needed it to drown out my girlfriend) #ad
'93 D250 210hp from mod pump and inj 5spd K&N filter straight exhaust
Merryman, It will work great as long as you don't want to talk any farther than you can throw a rock. Plus if you talk alot it will allow you to take your radio to the shop more often to get it repaired #ad
Regards Pete
99'3500,quad cab,4X4,a/t
3:54,all the right packages!
