After I changed my coolant I was adding to it each time from a cold start thinking that I was still purging air out of the block. This continued for about a week. I had the truck nosed into the garage and was doing something else when I noticed that coolant was slowly dripping onto the floor.
As I inspected to determine its source, I found that it was coming from the line going to the overflow tank right at the cap. I removed the line and there were no apparent cracks or splits. I then noticed that the overflow end of the hose had a clamp on it, but not the radiator end.
So, I installed a clamp on the radiator end, topped off with coolant and have not had to add since. BTW, no air in radiator either.
You were not specific on the location of your leak, so I hope that this helps.
