After about 9 month of using the water/methanol boost cooler I noticed that my Boost was not getting up as high as it used to and the EGT's where getting higher. Slowly it got to the point where the Boost would not get high enough to engage the water injection. I have the start point set for 15 psi and my boost would not get over 12 or 13 even with the TST power max box turned up.
I installed the 4" turbo back exhaust thinking this may be the restriction, but only help a little with the EGT's. The boost was still low.
I can not hear any leaks in the intake, but need to know if anyone knows a good way to check this.
I installed the ATS Aurora 2000 turbo thinking that my turbo may be failing. This did not help a thing.
I now have replaced the TST power max that was a few years old with the Edge Juice Attitude. This helped a little more with the EGT's but they are still getting very high even with the box turned down.
I am running out of ideas what could be restricting the boost and causing the EGT's to be so high.
Even with the low boost it still runs good until putting the pedal down or towing, then the EGT's are sky high. I have seen 1400 deg. without towing and the fueling box set on low. And it blows a lot of black smoke.
Help!!
Doug
Help!!
Doug
