Would you have to drop the tank to find the second return tank port?
Would the second port be fairly obvious, or could you post a pic of the tank module, or is it fairly obvious in the SM diagram (if there is a SM diagram).
Will the current fuel return mate with the second port fittings? Will they reach the second port without modification?
Is there much pressure on the return line? I would think not since it is open ended in the tank.
If we are going to cool the fuel, what about using something like a H7B (~ 27k) transmission cooler? LARGE capacity, LOTS of plates, use to HOT temperatures, designed for a more difficult job than cooling fuel, and you could put a fan on it as well for heavy use like heavy towing.
Probably overkill, but if you are going to do it, design extra capacity into the project and not do it twice.
Bob Weis
Bob Weis
