Our trucks have the high idle in cold weather enabled from the factory (mine does), but they don't have the 3 cylinder function enabled.
As long as the outside temps are below 32F, coolant temp below 140F, in park/nuetral, no throttle, no ground speed, the engine idle speed will increase to 1200 rpm after two minutes. Like clockwork.
Last winter I noticed that when it was around 10F or so, the engine would immediately go to the 1200 rpm idle at startup. I only remember the immediate fast idle when it wasn't plugged in. It would do the two minute delay high idle even when it was plugged in.
Don't have any experience with the 3 cylinder function.
