CDonaldson said:NPloysa.
You can make it work. All you have to do is remove the ECM B plug, push out the rubber plug in pin 22 (2nd row from the left, 3 down, looking from the back) Push in a new 18 gauge -10" piece of wire with the correct pin for the connector crimped on from the back side until it clicks, re-install the ECM B plug back into the socket, and ground the new wire you put into pin 22 onto the ground connector on the right side of the ECM. Works like a dream.
CD
