High idle install
Harness for dually tailgate lights
1989 W250 overcharging
Mount a PTO cable to the floor in the transmission tunnel and connect it to the throttle linkage (on the injection pump) with a slip type fitting that only pulls in one direction.
I took a high idle solenoid, Electricly operated from a mid 80's chevy, maybe a 454 type, and bent a bracket to fit on the front gear cover and a switch to turn it on with. I still have a vacuum operated one if interested. just have to run the tubing and valve to make it operable. they are adjustable.
