nfox,
High idle screw is on side of injector pump govenor. It is about 3 to 4 inches in front of low idle screw, it is one of these no tamper srews ( plugged with gunk). It is used to set max fuel flow to injector pump ( basically it changes the spring settings).
bmoeller is right there are two screw on backside of govenor. They usually have a wire threaded thru them so you can not adjust. They change fueling and by changing spring settings and/or angle of plate as I recall, some what risky to play with them.
If you want more fuel flow, a fuel plate would be more pratical this way you can always put back to stock performance by dropping the oem plate in.
Govenor spring kit will allow you to increase rpm above 3000 to 4000 rpm depending on which kit you get. ( which is increasing the rate of max fuel flow for a specific top rpm) I don't think of the govenor as defueling but rather staying at steady rate of fueling(maintains fuel flow) when it reaches the max, my truck doesn't slow down it maintains the same speed at my top rpm( little over 2600 in 5th and 2750 in 4rth).
