High Idler stopped working
edge comp...
PDR HX-40 silencer ring ???
I had used it a few times last week and i went to use it yesterday and nothing happens, i turned it all the way up with no response. Anybody have a similar problem? Suggestions?
EMD,
I assume you have a PS high Idler?? I have had that problem a couple of times... . I just wiggled the box a bit and twisted the wire harness and it worked. Maybe check the connections at the back of the box??
JR2
Hey Will check fuses? And connections wiggled? Odd that it just quit and thats it ya know. Being There's not much that can go bad on it anyways.
I will check the connections, I have'nt even popped my hood since i last used it so thats why i did'nt think to check the connections under the hood, but i will tommorow. Is there a fuse for the High Idler? And if so and it is blown, what would cause it?
