I am with you on this. 3 valves ,ok you cap the rail. what happens now when the pressure goes up? cracked rail, injector or something more expensive is right. relief valves in the system are great, you should leave it there at all costs. now a cp3 only makes 23,209 in stock form. what did you do to the cp3 to make it have more, I can tell you, nothing. just the programming feeding it, the cp3 stayed the same stock. I am not a fan of the rail cap, you want more there make a better valve,if thats the problem.
