High Ram Intake?
SCHEID Cam installed in 04.5....Results
Pacific Performance OBDII Reprogrammer
Bugracing said:
Does anyone have conclusive results on the benefits of the Banks Hi-Ram manifold. I am looking for dyno info on before and after installation.
This is what I posted back a page. I have the dyno sheet to prove it, I just don't have a scanner to scan it.
:) I have tried this on my '02 and it did give me 20 more horsepower. NO KIDDING. Now I'm not fond of Banks myself either (that's another story). I was at a Dyno event last year with my truck and the shop owner had one on the shelf and asked me if I wouldn't mind trying it on my truck because he wasn't sure if it did help performance? I said sure (as long as I'm not obligated to buy it), and he was cool with that. So I bolted it on right after my 1st and 2nd run of 445 hp and 449hp 30+ lbs of boost(truck still on Dyno), took 20 minutes. Fired her up and went right back to it with a run of 469hp and EGT's 75 degrees lower. I was pretty impressed I had to say, dyno numbers proved it. I actually would have bought it right there but I didn't have the money(of course I would have had to grind the "BANKS" off and repaint it). So that's my story with the "Hi-Ram". :)
Are you sure the difference in horsepower is not attributable to the engine being warmer on the second run?
-Ryan
sick_ram said:
Clint at ATS says it flows just as good as the Banks highram. The price is going to be around 350. 00 it is a little steep but if you seen how it was made you would know why. Look at all of the ports for the good stuff
that is a ludicrous price :rolleyes: ats is making a killing!
-Ryan
Well I took it off right after the second run and ran again and I was at the same horsepower as my first run. So in answer to your question, I'm going to have to say "No".
