High RPM and Exhaust Brake Failure
I have a 2001 Dodge with the HO engine, the 6-speed manual transmission, an aftermarket Pac-Brake exhaust brake, and about 77,000 miles on it. Everything else is stock. I have been experiencing a high idle (1000 RPM) and an exhaust brake failure on and off for over a year. On startup and short local drives everything is fine. If I drive about 40 miles on the Interstate, when I get off, the exhaust brake will not engage and the idle will be stuck high. The idle will not return to normal unless I shut the engine off and restart it. I do not have to wait long (30 seconds) to restart the engine. The other day, when coming off the highway, the exhaust brake was not activating, the idle was high, and the ABS dash light flickered a few times (new problem). I have had this idle/exhaust brake problem for over a year and it is really annoying me. The dealer doesn't have a clue, and they cannot reproduce the problem. The ambient temperature doesn't matter (90 degrees F, or 20 degrees F). Please help! Sometimes, the Pac-Brake will activate intermittenly when the problem occurs - in a 15 second 65 MPH to stop situation the exhaust brake might cut in and out two or three times.
I just signed up the the turbodieselregistry this week to find the answer to this problem. I hope it is out there.
