His front end shifted sideways !
P-7100 Delivery Valve Installation
Headlight switch problems.
I was having a little visit with a friend today who owns a truck similar to mine. I asked him how much his winch and grill guard had made his front end drop. We got to talking about our 2" lift kits we had both put in our front ends. (Too much lift for the winch saggage, we decided) He said that after a couple of months in his, the front end had shifted towards the drivers' side. He felt that raising the truck and not lengthening the track bar had caused it to pull over. He took the track bar down to a machine shop, had it cut and threaded, and made a coupling so he could adjust it. He lengthened it up to push the front end back to where it belonged. He said the lift kit manufacturer had never heard of this happening. Has anyone else ?
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps-Tuff Country control arms-2" coil spacers
Yep, I have the SkyJacker 2. 5" lift kit, I called Skyjacker up and told them about it. They said they have not had any complaints.
SkyJacker said to cut the track bar and weld a 3/4" piece of bar stock inbetween the two half? Kinda Hokie if you ask me.
So i Did the Same thing your friend did. Cut it, then thread it with LH and RH threads and bought a coupling. . Works like a charm. Why did'nt dodge do it that from the start?.
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,4. 10's,Suregrip,White Sport,Isspro Boost & Pyro,275hp Injectors,VA,PS Boost Module,DTT Valve Body,BD Pressure Lock,16x8 Eagles,285/75/16 Bridgestone MT's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
