Engine/Transmission (1998.5 - 2002) Hissing under hood...
I am a newbie at the 24 Valvers... I don't recall such a loud hissing when accelerating with my 12 Valve. :(
It sounds like a slit in my boot going into the intake side... or a hose that is relieving A LOT of pressure... :confused:
To make things worse... it stopped for a few days and then I could really here my turbo spool up :-laf - almost piercing and I loved it but now its gone...
Any takers or good guessing would be appreciated...
By the way - '99 4x4 QC LB Straight 3" exhaust - No ring - No boot - No idea why it hisses or why it stopped at one point... :confused:
Sounds like a boost leak... Well, hopefully it's in the boost side & not pre turbo... Should be easy enough to find with the help of a buddy in the cab.
R/Jim
Yep, sounds like a boost leak!
Check all your intercooler boots and tighten up all the clamps. Make sure none of the boots have slipped out from under a loose clamp!.
Well it looks as though the boot has slipped away from the Intercooler somewhat - so I will tighten that up and check other areas. I would imagine this is causing me to loose SOME HP due to not recovering part of the 33% energy recovery via the turbo boost... Ooohhhh - Not bad for a newbie huh :rolleyes: :D :D I'm probably wrong anyway ;) !! Ha ha...
Thanks for the advice... much appreciated!
Have you ever had a turbo diesel at all? Hoses would have been a good thing to check as soon as the suspect noise was discovered.
R/
Jim
R/
Jim
Well, we live in Texas, it coulda been a snake under the hood. :cool: bg
