I get a lot of good tips on the TDR. One of them was the "inspection of the IAT sensor. " It's a nice Sunday afternoon, so I decided to give it a shot. My truck has 26K on it and the only engine mod is an EZ...
Here is what you'll need... 3/8" ratchet; 13/16" deep socket; 6" extension.
Here is the problem... The IAT sensor is near the back of the engine, on the drivers side. It is extremely difficult to get back there as you have to weave your arm through wires, and get past the oil dip stick support bracket. Once your there, it is difficult to remove the two wire harness, as it has a snap tab on it, and unfortunately, on my engine, the tab is on the back side of the IAT sensor. After many minutes of working on this, and a lot of scratches on the old arm, I finally was able to get the tab connector off. Then you have to get the socket on it and turn it off (once again... not a lot of room to work).
Once I got it out (after asking myself why I even started this) there was hardly any soot on the sensor at all. Cleaned what was there with carb cleaner (so at least I could feel like I hadn't totally wasted my time) and then begin the process of getting it all back together.
Took about 30 minutes and my recommendation would be to leave it alone, unless you suspect you have a problem (i. e. higher mileage engine, loss of power, reduced MPG, etc)... . Just my $. 02 worth... .
