Engine/Transmission (1998.5 - 2002) Hole in floor
Engine/Transmission (1998.5 - 2002) blow by bottle modification...
Engine/Transmission (1998.5 - 2002) Prep. to remove VP44
I know someone has done the change from auto to 6 speed. I was just wondering if the hole for the 6 speed shifter is already in the floor?
Thanks, Ron
Thanks for the reply's. It's good to know that there is only one floor pan. If I decide to switch from my auto to the 6 speed. I will only have to cut the carpet, it would be a pain to try to get hole in the right place for the shifter.
Thanks again, Ron
the hole IS NOT in the floor.
Kind of a PITA to locate. I cut a smaller hole than needed, then kept cutting away until I could fit the trans in place. There is an inner shift boot that you can use as a final quide (to make sure your hole isn't too large). To me, this is the only real unkown in the trans swap.
Everything else is a direct bolt-in. There are even dimples on the firewall for locating the clutch master cylinder.
Keep in mind that you will need to ground one of the wires from the original auto trans wiring harness (park/nuetral)
HTH
George
