Engine/Transmission (1994 - 1998) Holset WH1C
Engine/Transmission (1998.5 - 2002) Cummins Torqus Maximus
I know on my 94' that i have a holset WH1C turbo. What is different from this and a HX35. Is it better or worse. I would like to get some info.
I've been told they are very similar, especially when you compare the performance curves. I called the guys at htturbo with the same question and recommend you do the same; good guys to talk to and I got straight answers. Our trucks don't make as much boost pressure because of less fuel from the 160 pump. I don't think there is any advantage to switching a stock WH1C with a stock HX-35. I almost learned this the hard way.
I also have the WH1C turbo which has been modified with the Banks exhaust housing that was included with their Power Pak kit.
With the Banks plate, boost seldom exceeded 20# but the truck handled my 7000# trailer quite well and egt's were not too much of a problem. It didn't come off the line real fast but picked up when the governor began fueling.
My first experiment with changing plates was to try the TST #5. It started a little slow but produced great acceleration which continued throughout the throttle range and boost would peg my 30# gauge. The problem with that was towing. I had to keep a sharp eye on the egt. It came up fast and was hard to avoid under some situations.
Today I installed a #10 and the test drive shows good acceleration from a dead stop up to between 70 and 75 mph where it begins to de-fuel. Boost is much less, max at about 25# but egt is much slower to rise.
The proof will be in how it tows.
Getting back to the issue of this thread, I think the WH1C is more than adequate for the unmodified 160 pump and it can produce plenty of boost with adequate fueling.
:-laf I guess your right, i hate my 160 pump, it only lets my big single make about 65psi at WOT. :-laf
I could hit 32 lbs. with my #10 plate before the 370s. I've been a lil afraid to see how much it well go to with the 370s since i still have the stock head gasket.
Nathan
ALehman said:
why did they change to a hx35 for 95 and only run the wh1c for one year
Only trucks made before Jan 1 94. That was the emmissions hit that forced cummins to give us the P pump and a cat. The early 94's had the WH1C, i dont theink they had a cat, too.
my 95 has a wh1c i also thought about switching to a pdr 35, e gaskamp hit 48 psi with his whc1 after installing delivery valves it scared him so its gated down to 40.
i hit 36 psi every day or almost every day and i can get 38psi mine has the wh1c and it is most likely well past it's effective range at those levels but oh well =)
